Results 1 to 2 of 2
Thread: Working principle HF transformer
20-07-2008, 02:12 PM #1
Anyone noticed yet the High Frequency transformers - sometimes called switch mode HF transformers - you see on the PCB's of nowadays electronic equipment?
This is one and
This is a type you often see in AC's
In every decent AC, you will find some of these.
Sometimes a 2 kW transformer is crunched in a housing of only 2 inch high on a footprint of only 3 x 2 inch and it weighs almost nothing compared to a normal transformer.
A normal 2 kW transformer is a real heavy peace of copper and iron
Does anyone know of a link of the working principle?
20-07-2008, 02:32 PM #2
Re: Working principle HF transformer
Sounds like one our friend Star882 could answer!
Not my area of expertise, but here goes.
I copied this from the link below.
http://mrtmag.com/mag/radio_switching_vs_linear/
The basic technology behind switching transformers is: As the rate of change of the magnetic field increases in the transformer (i.e., increase in switch frequency), the transformer can be made smaller with smaller cores and wires to produce the same output power. Lighter core materials such as ferrite can be used instead of laminated iron. The resulting transformer assembly becomes much smaller and lighter than its linear counterpart.
Working outside your home country
By US Iceman in forum Chit Chat & Service StoriesReplies: 10Last Post: 29-07-2008, 04:05 AM -
Porable tool transformer
By chiller-man in forum ElectricalReplies: 17Last Post: 13-06-2008, 12:39 PM -
OIL SEPARATOR not working properly
By PEPELEBU in forum Trouble ShootingReplies: 14Last Post: 05-05-2008, 04:16 PM -
working hours
By jan behnke in forum Chit Chat & Service StoriesReplies: 11Last Post: 17-07-2005, 12:31 PM -
is my fridge working properly?
By vincec in forum Trouble ShootingReplies: 1Last Post: 15-01-2002, 09:55 PM
