Thread: question on qualitair
27-06-2008, 10:40 PM #1
went to look at a qualitair cellar cooler plant. fault found with cond fan motor causing comp to cut out on overload. No model No or serial on condenser unit housing. Looked on wiring diagram which says Fan motor Q090. The motor is single phase LEMAC 120watt PSC type ( 54543-310 ). I would be very grateful if somebody has a number for Qualitair in the UK. It is quite old equipment R22 charge. The motor as a orange circular molded blade. Any help would be much appreciated.
28-06-2008, 12:14 AM #2
Re: question on qualitair
Hi Mcunliffe,
I think those units had a smaller motor when new with a 5/16" shaft. The blade has a half inch hole and there is a bush that goes in to make up the difference. The fan pushes the air through the condenser rather than pulling as is more common.
SRW list a 35W motor for qualitair/marstair units its a four bolt rear mount motor.
If the motor you have is cradle mounted and a 1/2" shaft it sounds like somone has fitted a prestcold style motor. SRW also sell these though they are also available from RPW and Climate centre.
You may be better fitting another one like this if the original motor bracket and fan blade bush is missing.
Or i could be completely wrong
I usually take the duff motor and blade to the wholesalers so that i can be sure getting the right part before returning to site, learnt this the hard way
Jon
29-06-2008, 03:16 PM #3
thanx mate, think ill take motor with me to wholesale
29-06-2008, 03:47 PM #4
What was said +
Check the rotation of the motor, as I've had replacements supplied, only to find that they supplied a clockwise rotation instead of a counter clockwise rotation.
Just might save you some frustration later on
Heat Transfer Exam Question
By alexdouglas1969 in forum FundamentalsReplies: 10Last Post: 13-12-2008, 04:19 PM -
Refriferation cycle question
By ozmecheng in forum FundamentalsReplies: 32Last Post: 26-03-2008, 10:38 PM -
Newbie with a question
By AcidSlasher in forum FundamentalsReplies: 4Last Post: 07-03-2006, 11:20 AM -
quizy type question thingy
By rbartlett in forum Chit Chat & Service StoriesReplies: 25Last Post: 06-02-2006, 09:22 PM -
Urgent, Kirchoff question
By Peter_1 in forum FundamentalsReplies: 4Last Post: 20-01-2004, 03:12 PM
