Thread: the best torch
10-11-2003, 01:14 AM #1
the best torch
hello all my name is milton my home is brazil i to like forum is my first time i have one torch bernzomatic model t751 is good what is the best torch for refrigeration thank all and good luck sorry my english i speak portugues
12-11-2003, 08:27 PM #2
Hi Milton
If you are brazing refrigeration quality copper then you need high temperatures. The best solution is for an oxy-acetylene torch as these are controllable by selecting the correct nozzle for the job. On smaller pipes you can get away with using a blowtorch burning a propane/acetylene mixture.(sometimes called Mapp gas).
My favorite is the oxy/acetylene.
Frank
12-11-2003, 11:10 PM #3
For what it's worth. I use a Uni-Weld oxy-acetylene rig with Captain hook tips. surrounds the pipe totally for high temp brazing, Also ahave an acetylene only tip (fits on a 00 tip for lower temp work and thawing Ice.
08-02-2004, 01:38 AM #4
Hi Milton
For higher temperatures, use an oxy acetylene set up, or for smaller applications, MAPP gas fitted with a sure fire 2 torcha problem shared is a problem halved
Torch
By Peter_1 in forum IndustrialReplies: 7Last Post: 17-07-2009, 04:53 PM -
solder fell into torch tip
By star882 in forum Chit Chat & Service StoriesReplies: 5Last Post: 01-01-2006, 11:53 PM
