Results 1 to 21 of 21
Thread: Help, advice needed.
Threaded View
29-10-2003, 08:46 PM #14
Now do know that all it does is switch back and forth the start and run power supply to make it run backwards. Switch the Start and the Run wire and make it run backwards for a few seconds. The put it back to run forward.
Does this make sense?It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
Advice Needed On How Int/ext Fans Work
By nconti in forum Air ConditioningReplies: 3Last Post: 06-08-2006, 11:06 PM -
advice needed on overhaul hours
By stewartreith in forum Industrial CompressorsReplies: 1Last Post: 15-05-2006, 08:59 PM -
Advice Needed!
By Tim_Uk_Trainee in forum TrainingReplies: 4Last Post: 05-06-2005, 11:01 PM -
Advice for newbie - please be kind..!
By electricstuff in forum Air ConditioningReplies: 11Last Post: 04-10-2004, 06:52 PM
