Thread: Ruptured oil filter
30-08-2003, 08:04 AM #1
Ruptured oil filter
Hi!
A Bitzer screw comp'r. running on R22 in an aircooled chiller called for malfunctioning of unloader mechanism.
Opened at the shop, we found ruptured oil filter. What could be the cause?
Please refeer to the attached pic.
30-08-2003, 08:30 AM #2
Attached Picture? Sorry, here is it anyway.
30-10-2003, 07:02 AM #3
Sugestion because we had the same with an oil filter in an oil separator of AC&R
1 st almost completly clogged due to dirth on the filter element itself (paper/mesh..)
2nd rupture of the casing due to excessive out-of- design pressure.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
Attention! Air Conditioning Filter Experts I Need Help
By hoffa4444 in forum Air ConditioningReplies: 4Last Post: 10-07-2006, 09:43 AM -
special air filter
By 27143721 in forum Technical SpeculationsReplies: 5Last Post: 12-06-2006, 07:09 AM -
AAF HEPA filter
By watana in forum Air ConditioningReplies: 2Last Post: 02-04-2005, 12:09 PM -
Stainless Steel Filter Body
By Derek in forum IndustrialReplies: 2Last Post: 10-04-2003, 06:25 PM -
DW Copeland
By Abe in forum Trouble ShootingReplies: 18Last Post: 19-11-2002, 02:54 PM
