Results 1 to 1 of 1
Thread: Daikin Controls
16-04-2008, 10:12 PM #1
Daikin Controls
In order to provide supplemental heat from a secondary heat source when the outdoor temps are very low, a Daikin VRV-S has an add-on PCB. This board has a set of terminals (YC – Y1) that provides a voltage signal when the indoor temp drops 4*C from the controller set point. This voltage signal would be used to bring in the supplemental heat. The circuit opens back up when the temp has risen 2*C.
Does anyone know whether the 4* value can be changed by the controller to a more reasonable 1 – 2*C drop? Ideally, the circuit would close when the temp in the room dropped 1* and opened again once the temp had risen .5*.
Daikin not working... many problems
By stankovicv in forum Air ConditioningReplies: 26Last Post: 11-12-2010, 09:01 AM -
Daikin, Why do we bother?
By gwilliamson in forum Air ConditioningReplies: 21Last Post: 02-02-2010, 09:38 AM -
Daikin Comp and inverter
By WCC73 in forum Air ConditioningReplies: 5Last Post: 08-11-2008, 08:44 PM -
Daikin Analyzer
By marc5180 in forum FundamentalsReplies: 10Last Post: 02-08-2008, 07:15 PM -
incorporating heating controls into daikin a/c
By rbartlett in forum Air ConditioningReplies: 33Last Post: 09-01-2006, 10:19 AM
