Results 1 to 8 of 8
Thread: Condenser Coils
11-04-2008, 08:49 PM #1
Condenser Coils
Hi , you know when you get one of them really greasy condensers, full of sticky greasy dirt which despite all your efforts you cant seem to clean effectively,. Do you know of anything that will remove this ****e without having to remove or renew the condenser coil.
regards phil
11-04-2008, 08:55 PM #2
Re: Condenser Coils
Hi Phil
Grease Gobbler from Climate Centre or Hrp.
Spray it on with spray bottle and leave o/nite and then spray with clean water next day.
You might have to do it a couple of times as getting that stuff off is a pig.
There is more potent stuff on the market but if you get the wrong consistancy it melts the fins.If it ain't broke, it doesn't have enough features yet.
Damo
11-04-2008, 08:56 PM #3
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Condenser Coils
I use successfully Rectroseal Renewz and Clean-n-Safe!
http://www.rectorseal.com/index.php?...&product_id=17
You should consider this for grease!
http://www.rectorseal.com/index.php?...&product_id=59Last edited by nike123; 11-04-2008 at 09:00 PM.
12-04-2008, 12:34 AM #4
Re: Condenser Coils
Cheers yer tried grease gobbler but it stunk the area out well bad and turned the flames green on the gas ovens in the kitchen lol
12-04-2008, 12:43 AM #5
Re: Condenser Coils
i use
http://www.dehon.com/gb/index_gb.php...tion=3&idn3=18
always find it works well if you leave it to soak,also a steam gun (wallpaper remover) ive used in the past on indoors and brings them up a treatPaul
"KEEP IT COOL"
12-04-2008, 10:07 PM #6
Re: Condenser Coils
super clean excellant stuff brimgs them up like new. really powerful
13-04-2008, 02:29 AM #7
Re: Condenser Coils
I spray it with some Renewz and then use a steam cleaner after it sits for a few minutes... good as new!
14-04-2008, 02:39 AM #8
Re: Condenser Coils
Vapco makes Power Clean..safe to skin but soaks thru grease with no odor. Rectorseal has { ? } ConCoil but is ACID BASED. Diluted it still works great but BE CAREFUL!!. Used when nothing else worked. Just flush down well and use glasses for splashback. Sometimes you just have to condemn the coil... all about time and final result. GOOD LUCK!!
Best way to clean condenser coils?
By BlueVanACD2005 in forum Trouble ShootingReplies: 13Last Post: 23-09-2007, 06:20 PM -
Condenser Coil Positioning
By marks in forum FundamentalsReplies: 3Last Post: 02-07-2007, 03:03 AM -
Optimum condenser fan speed
By star882 in forum FundamentalsReplies: 4Last Post: 27-02-2006, 01:50 AM -
Liquid trap
By Herschmidt in forum Supermarket RefrigerationReplies: 1Last Post: 13-08-2005, 11:39 PM -
Cleaning clogged condenser coils of grease
By Abe in forum CommercialReplies: 10Last Post: 05-10-2003, 03:47 AM
