Thread: Panasonic fault codes
11-04-2008, 11:08 AM #1
Hello, me again..
Would anyone have fault codes available for panasonic, unit CU-A50BBPB..R22.
Thank you in advance
11-04-2008, 09:14 PM #2
Re: Panasonic fault codes
Hi there, you again..
I did a search on here and found an old post of mine.....
Likewise I couldn't find your model on the Panasonic site, did you get to this page---
http://www.panasonic.com/consumer_el...ac/manuals.asp
there might be a similar control setup on one of those; might be worth a look.
There are some CU models so hopefully there might be something there for yours.Brian - Newton Abbot, Devon, UK
12-04-2008, 12:00 AM #3
14-04-2008, 12:40 PM #4
Thank you Brian and Superswill, will phone panasonic to get relevent manual..
14-04-2008, 08:44 PM #5
Fault codes for the larger units are inside outdoor unit compressor cover panel.
Whats the fault code? I've got the service manuals for it, but because I have to compress images so much here, they end up illegible.
I'll need the indoor code, and what LEDs on the outdoor are flashing.
But they are always on the outdoor unit for the larger ducted anyway (though it might have been weathered away or taken by someone else ).Last edited by paul_h; 14-04-2008 at 08:56 PM.
15-04-2008, 12:11 PM #6
Hi paul, i did check outside unit and found all relevent codes there, unit had a pin prick leak on discharge pipe, thus lack of ref, al sorted now, thank's for replying.
Nick.
Panasonic Fault codes
By ronaldo9 in forum Air ConditioningReplies: 31Last Post: 20-02-2011, 08:57 PM -
carrier fault codes
By richelli in forum Trouble ShootingReplies: 5Last Post: 18-06-2010, 07:35 AM -
panasonic fault codes
By coolflow in forum Air ConditioningReplies: 7Last Post: 16-12-2009, 02:50 AM -
Daikin fault codes
By Markie in forum Air ConditioningReplies: 16Last Post: 13-01-2009, 01:58 AM -
standardisation of fault codes?
By kelvin kline in forum Air ConditioningReplies: 1Last Post: 10-10-2007, 12:30 AM
