Thread: Computers and transport fridge
18-03-2008, 03:30 AM #1
How do you all get on with laptops and transport fridge with associated peripherals?
I've recently had to program a few incab printers and it was a pain in the backside really for one reason or another, I won in the end!
I'm also quiet interested in Carrier and Tk software, I have seen a few screenshots but nothing in the flesh, how integrated are laptops into the brains of the big diesels, what can you see?
04-04-2008, 06:21 AM #2
Re: Computers and transport fridge
You can pretty much see anything you want. All the logging you want as well as there are parameters of the machine itself that can be programmed.
They have come a long way in the past few years.
07-04-2008, 04:21 PM #3
Transport refrigeration units have not gone to Electronic controlled engines as of yet. Still using mechanical fuel injection pumps and Injectors.
There is a couple sensors on the engine that will report back to the base micro controller, for either engine protection and or refrigeration sytem protection via units with ETV.
They are digital or analog as followed: Engine water temp sensor, oil pressure sensor and or switch, engine flywheel sensor, oil level switch, coolant level sensor or switch. Engine speed is controlled by electromagnetic solenoid, not a variable throttle position, but rather fixed two speeds. low speed and High speed.
Engine sensors will be the analog feed, and swithches will be digital feed.
A-Z
07-04-2008, 10:48 PM #4
09-04-2008, 06:11 PM #5
