Thread: contorl system
10-03-2008, 10:41 PM #1
contorl system
Hi.
I have an clamavita air cooled chillers with 6- reciprocating piston compressor Copland type with problem in the old type main control system and I want to replace it with a new one. please can u advice me which control can I use .
The chillers has two circuits with 3-compressors and 6- fans foe each.
10-03-2008, 11:05 PM #2
Re: contorl system
It all depends on how complicated you want to make it.
In the simplest form, all you need is a multi-stage thermostat , a couple (well, 6) contactors and a bunch of relays.
On the other end, you could fit an outstation, a bunch of relays and take full control from a BMS system.
The options are endless and the sky is the limit (well, one assumes the customer's budget also will, somewhat, limit the choices available)
10-03-2008, 11:26 PM #3
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: contorl system
I would go with Elywell Energy XT
http://tinyurl.com/yubo9c
or Carel MicroChiller3 if compressors are hermetic ones:
or Carel pCO if they are semihermetics:
http://tinyurl.com/3b9u5t
11-03-2008, 01:13 AM #4
Daikin fault codes
By Chris2005 in forum Air ConditioningReplies: 45Last Post: 21-03-2012, 10:09 PM -
Leak Testing?
By Thana in forum Trouble ShootingReplies: 36Last Post: 31-08-2010, 02:57 PM -
System Burn Out Troubleshooting
By altaf22m in forum Technical DiscussionsReplies: 13Last Post: 07-05-2010, 09:24 AM -
Burn out System, Clean up procedure. & Troubleshooting.
By altaf22m in forum CommercialReplies: 19Last Post: 15-04-2008, 07:03 PM -
Refrigeration system proposal; comments please.
By DaBit in forum Technical SpeculationsReplies: 13Last Post: 01-01-2003, 03:42 PM
