Thread: Airedale Cus10
28-02-2008, 10:12 AM #1
Airedale Cus10
Hi, i have 3 airedale condensing units, all with no model/serial number and no other details at all except its compressor is a maneurope 160p. i think they are either CUS10's or CUS12's...
could anyone give me as much info about these units as possible. pictures would help to if available. thanks.
28-02-2008, 11:21 PM #2
Re: Airedale Cus10
Hiya chances are that 160 p Maneurop is the oil type.
What do you want to know??
R1 usually means cooling signal active, R3 usually fault relay. Only got HP, LP, and some have discharge gas temp stat. They really are quite simple units with not much that can go wrong.
28-02-2008, 11:28 PM #3
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Airedale Cus10
This is technical manual:
http://tinyurl.com/3cfefc
29-02-2008, 05:18 PM #4
Re: Airedale Cus10
just wanted to know what they were really. we are moving the 3 condensers and AHU, and the client wanted to keep some info on them and it would be helpful for our O&M manuals too. after finding an old airedale catalogue (the same as the link nike123) gave, i found they were CUS12's n got all the info i needed.
Thanks for the help!
Airedale alarming!
By Jase in forum Air ConditioningReplies: 2Last Post: 07-02-2008, 03:25 PM -
Fault on an Airedale unit
By marc5180 in forum Air ConditioningReplies: 50Last Post: 30-06-2007, 06:10 PM -
Airedale Ducted Type Cmx 15d
By Pravin in forum Refrigeration BooksReplies: 3Last Post: 25-04-2006, 05:58 PM -
airedale
By marley821 in forum Air ConditioningReplies: 2Last Post: 24-03-2006, 08:07 AM
