Thread: mitsubishi
16-02-2008, 12:27 AM #1
mitsubishi
i finished the installation of a mitsubishi a/c and icame to say hello! in another a/c i had problems with the ground,i had 25 milivolts measured? i think that the compressor doesn"t works good... any suggestions? thanks...
16-02-2008, 11:53 AM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: mitsubishi
Is it inverter type of AC?
Did you mean 25mA?
17-02-2008, 06:59 PM #3
Re: mitsubishi
If you have any Voltage on the earth terminal, there is a problem with the earth wiring, not necessary with the machinery attached to it......
17-02-2008, 08:21 PM #4
Re: mitsubishi
25 millivolts?is the compressor running?if you're not happy with your readings,use a mega meter and trace wires from the mains,you should find th location then.Looks like you enjoy installing them mitsubishis,hey.Fault finding is a brain teaser,aint it?Good luck buddy...
07-04-2008, 12:44 AM #5
Re: mitsubishi
thanks to all!!! but im still trying!!!!!!
Mitsubishi vrv
By dakesojo in forum Air ConditioningReplies: 20Last Post: 22-09-2009, 01:04 PM -
Mitsubishi Light Truck Refrigeration
By Mastercool in forum TransportReplies: 2Last Post: 23-11-2007, 06:15 AM -
mitsubishi city multi fault code
By robin r33 gtr in forum Air ConditioningReplies: 5Last Post: 05-11-2007, 10:23 PM -
Mitsubishi compressor lock
By marc5180 in forum Air ConditioningReplies: 29Last Post: 08-10-2007, 05:48 PM -
Mitsubishi SRK
By daddymac in forum Air ConditioningReplies: 1Last Post: 26-04-2007, 08:47 AM
