22-01-2004, 07:12 AM #1
Thanks Prof Sporlan,
"The Prof will assume this system has two TEVs with check valve bypasses and side connection type distributors. "
The system has a biflow exp. valf and heat pump so there is no any check valve bypasses...
Could you please examine the above datas according to the last situation?
Best regards
Fitting an expansion valve question
By Larry2 in forum Air ConditioningReplies: 20Last Post: 08-04-2008, 04:17 PM -
:rolleyes: capillary tube size in distributor?
By abbasi in forum New TechnologiesReplies: 2Last Post: 08-07-2006, 03:56 PM -
Internal V's External Expansion Valves
By Latte in forum FundamentalsReplies: 9Last Post: 25-06-2005, 01:12 PM -
exp valve
By bernard in forum CommercialReplies: 16Last Post: 29-08-2004, 07:11 AM -
TXV's and LST compressors
By DaBit in forum Technical SpeculationsReplies: 32Last Post: 18-06-2002, 02:27 PM
