    3,856
    Pego controllers
    Does anyone know what the 'haccp' button is for?
    Now, i've learnt my lesson with pressing things when i don't know, sometimes i get a slap, sometimes it stops working, sometimes nothing, so i left it alone
    Couldn't make any sense of the Pego site and the customers have lost the destruction...
    Cheers Jon
    Dec 2004
    U.K
    55
    518
    21
    Re: Pego controllers
    I don't know what it's for but I think Thermofrost Cryo do the Pego range, you could try asking their technical bods?
    Let me know if you need the phone number.
    regards,
    djbe.
    3,856
    Cheers, i'll give them a call.
    Jon
    Somerset
    69
    4,706
    Thumbs up Re: Pego controllers
    Cheers Jon
    Hi Jon
    Yes thermofrost Cryo are distributers also SRW.
    If all else fails you could try Pego themselves.
    On the link below.
    As far as I am aware it's restricted to sales literature unless you go through their Tech Dept though?
    Cheers Steve
    http://www.pego.it/Eng/Prodotti/Default.asp
    Oct 2003
    5,630
    34
    To use this button, you must insert a special datalogger module (SPZ0001) into the PCB of the PEGO, mostly on the front panel.
    65.000 measurements then can be stored into this PCB
    Jul 2007
    Australia
    1,845
    Cheers Jon
    It's probably the same as haccp in carel controllers. haccp is monitoring for alarm situations like high temp etc that allows users to know that whatever was stored in the fridge has been outside preset conditions.
    Eg, stick in a normal controller without it, the users only know the blood or food is over temp if they see the fridge over temp.
    haccp equipped controllers will go out on alarm until the users reset the alarm, so even if it happened over night or when they weren't there, they know the cabinet went over/under temp. It can also be hooked up to other devices or comms to deal with the alarm.
  1. Daikin Controllers
    By MadMax in forum Heat Pumps
    Last Post: 22-07-2008, 03:46 AM
  2. Hitachi Controllers and Mitsubishi Grills
    By Radlam in forum Air Conditioning
    Last Post: 19-12-2007, 09:03 PM
  3. carel ir33 controllers
    By fowlie in forum Supermarket Refrigeration
    Last Post: 17-12-2007, 07:14 PM
  4. QKL Controllers
    By dallan in forum Commercial
    Last Post: 18-02-2006, 03:48 PM
  5. Liropa Controllers (Linde Fridges)
    By Latte in forum Refrigeration Books
    Last Post: 25-02-2003, 09:17 PM
