Thread: Samsung AQ12F Help
02-01-2008, 06:37 AM #1
Samsung AQ12F Help
Hi Please can someone shed some light on a new Samsung AQ12F thats just stopped working! Had it installed 2 days ago. breakers to the aircon all fine..Is there possibly a reset button?
WarrenLast edited by beemerstyle; 02-01-2008 at 06:47 AM. Reason: question to ask
02-01-2008, 08:10 PM #2
Re: Samsung AQ12F Help
I would call back the installers straight away as it might be a major failure, or not, which could be covered under warranty.
If you start playing with it then the warranty might be voided.Brian - Newton Abbot, Devon, UK
02-01-2008, 08:26 PM #3
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Under the lid of indoor unit, you probably have pushbutton . Press it once. If unit start, then you have problem with remote control. If don't, you have problem with power supply or electronic circuit board, then call service.
But first, carefully read user manual, maybe there you could find answer to your problem.
Samsung Error codes
By kevscontent in forum Trouble ShootingReplies: 10Last Post: 08-08-2010, 06:20 AM -
Samsung RS21 DCNS Fridge too warm
By Divekate in forum Trouble ShootingReplies: 1Last Post: 26-02-2007, 05:12 PM
