Results 1 to 10 of 10
Thread: cap tube pumps
02-04-2003, 02:13 AM #1
cap tube pumps
please settle an argument between me and my boss. Does anyone belive in clearing plugged cap tubes with a cap tube pump (hydrolic type pump that uses high presure refrigerant oil to clear puugged lines). My boss uses one, I did refrigeration for 5 years before knowing what one was. Every time I have asked an O.E.M they have said not to use them and to just change the cap tube.
03-04-2003, 03:19 AM #2
I have never actually used one. I know Johnstone sells one that pushes a tiny piece of metal htrough the tube. Once the metal is pushed through it stays in the evap. That does'nt sit too well with me, but then again if it is a cap tube that is too difficult to change, what do you have to lose?
John K.
04-04-2003, 06:28 AM #3
I do think that is what my boss was talking about. has anyone used one or considered one
07-04-2003, 07:41 AM #4
I bought one that uses oil to clear a clogged cap tube. Haven't used it yet. THe book says it can produce up to 2000psi. I don't think the copper tubing will hold it though. It should either clear it or destroy it.
I visit http://www.fuel-saver.org
22-04-2003, 11:39 AM #5
The wall thickness of a captube, compared with the inner diameter, is very high. A captube should be able to handle 500 bars without problems. Thus, using high pressure oil might be able to clean out the captube. But captubes are cheap, so why not replace it when possible?
22-04-2003, 07:24 PM #6But captubes are cheap, so why not replace it when possible?
Frank
26-05-2003, 07:40 PM #7
I bought one eons ago, when I was young and had to have every tool that I could find. (Now I'm old, and have to have every tool I can find...)
It does work very well, and with the introduction of the POE oils, it saw a move from the back of the garage to the truck. Works great.
They're not super-popular, but are still available:
http://www.thermal-eng.com/HTML/5101.htm
They do work well, but are a bit messy.
26-08-2007, 02:51 PM #8
Re: cap tube pumps
I used one home maid and put into cap tube R 11 under pressure over 400 bar! Successfully!
26-08-2007, 03:02 PM #9
Re: cap tube pumps
27-08-2007, 07:32 PM #10
Re: cap tube pumps
You see them on ebay all the time as cap tube chasers. I never really saw the point as I stick strictly with TXV systems.
But, as others have mentioned I suppos it does indeed have its merrits.
oxidation scale in copper tube and fittings
By DeB in forum FundamentalsReplies: 8Last Post: 23-06-2006, 09:45 PM -
Heat Pumps
By US Iceman in forum IndustrialReplies: 11Last Post: 14-04-2006, 07:29 PM -
metric capillary tube
By tralex in forum FundamentalsReplies: 5Last Post: 21-02-2006, 06:57 AM -
The amazing Mr. Cap Tube
By shogun7 in forum DomesticReplies: 52Last Post: 07-01-2006, 07:33 PM -
Tube staggered/squared
By bersaga in forum FundamentalsReplies: 2Last Post: 05-01-2003, 11:56 PM
