    Jun 2005
    Lancs
    61
    Adam 2000 Building Management System
    Has anyone come across this system ? If so could you advise on what kind of software that may be used to edit the settings. Adams themselves say on their website that no special software is needed , however I would deduce that "some" kind of software would be required to interface with the panel. Any help or advice is greatfully appreciated.
    Steve
    11,025
    Re: Adam 2000 Building Management System
    As they say 'standard communications software I would assume that Terminal Emulator would get you started.
    Jun 2005
    Lancs
    61
    Thanks Brian
    I did try a couple of different programs but they couldn't see the panel. Ah well looks like it's back to basics , remove the panel and fit timers.
    Steve
  1. Daikin fault codes
    By Chris2005 in forum Air Conditioning
    Last Post: 21-03-2012, 10:09 PM
  2. System Burn Out Troubleshooting
    By altaf22m in forum Technical Discussions
    Last Post: 07-05-2010, 09:24 AM
  3. Replies: 19
    Last Post: 15-04-2008, 07:03 PM
  4. help building an inverter system
    By max2 in forum Air Conditioning
    Last Post: 31-07-2007, 08:36 PM
  5. Refrigeration system proposal; comments please.
    Last Post: 01-01-2003, 03:42 PM
