    Towbar's Avatar
    Towbar Guest
    Bosch KGV3120GB Fridge/Freezer
    Help Wanted please
    I am a retired Electrician/CCTV engineer, recently after my wife defrosted the
    freezer, and when switched back on again, the compressor did'nt start up. I put the supply straight to compressor and it started to run ok. I am sure the termistor is faulty. I have heard that if I cut the wires to the termistor and twist them together the machine will work ok and will be controled by the temperture control on the panel. But with no thermistor, what controls the freezer temperature?
    If I get a replacement termistor, is it difficult to fit? Any help would be appreciated.
    Towbar
    Jul 2006
    norfolk
    737
    Re: Bosch KGV3120GB Fridge/Freezer
    join the 2 middle wires together (Dark Blue with Dark Brown) and it will work and should carry on as norm,as for replacement termistor,they very easy to fit
    Towbar's Avatar
    Towbar Guest
    tono33
    Thanks for that info. I will try that, and fit new termistor when I have sourced one.
    Towbar
  1. Replies: 6
    Last Post: 25-10-2010, 01:25 PM
  2. Bosch Fridge Freezer Error Code ??
    By madfriday in forum Domestic
    Last Post: 29-04-2010, 09:01 PM
  3. Westinghouse Silhouette 391 fridge/freezer
    By Bones in forum Domestic
    Last Post: 04-05-2007, 03:05 PM
  4. lg fridge/freezer fault light on function display board
    By bazza in forum Trouble Shooting
    Last Post: 25-02-2007, 03:25 PM
  5. RFI Interference from Fridge/Freezer
    By pathfinder in forum Trouble Shooting
    Last Post: 19-03-2005, 11:50 AM
