Results 1 to 8 of 8
Thread: 3 phase motor
    mostafa_bostan's Avatar
    mostafa_bostan Guest
    3 phase motor
    Hi, more about 3 phor wiring?thanks
    11,025
    Re: 3 phase motor
    Try Google, your question does not ask anything specific.
    progzmaster's Avatar
    progzmaster Guest
    Re: 3 phase motor
    Quote Originally Posted by mostafa_bostan View Post
    What would you like to know?
    Nov 2007
    Saudi arabia
    Re: 3 phase motor
    motor type ?power or controll??????????????????????
    Oct 2003
    5,630
    34
    Re: 3 phase motor
    What the hell is a 3 phor wiring?
    You can mount the motor vertically or horizontally.
    If mounted vertically, watch out for the oil which can drip out.
    If you turned it upside down, let it stand sill for at least 6 hours.
    You must connect power on the wirings.
    Never, but never touch the wirings with your bare hands.
    Jan 2007
    Georgia
    72
    32
    Re: 3 phase motor
    I would use a little caution when mounting a general purpose three phase motor vertically. The shaft bearings have to be rated for vertical mounting and if not this will greatly reduce the bearing life on the motor. A lesson I have already sorely learned.
    malaysia
    159
    Re: 3 phase motor
    mostafa,
    you should run thru
    1] fuji
    2] merlin gerlin website
    they have good bulletins on this.
    i think you are looking for a good start to understand 3 phase wiring.
    each country has its 3 phase power distribution concept; get to know that before going to any other means.
    82
    74
    Re: 3 phase motor
    Dunstable 1965 3000horse power 3phase motor rotating cement manufacturing drum could only be started in the early hours had a large motor connected to the shaft to help get it going.3 windings in phase =clockwise out of phase=anti clock ie change over any two wires,power factor correction, reduce running costs fit capacitors ,speed control DC injection, inverter,variable voltage,slip rings connected to a bank of resistors all from memory correct me if i am wrong
    Grump
  1. Compressor loading, cooling, and range of operation.
  2. Fan Motor Electrical Problems
    By Rotax100uk in forum Electrical
    Last Post: 21-07-2007, 12:00 PM
  3. dual voltage fan motor
    By bill1983 in forum Electrical
    Last Post: 09-05-2007, 10:36 PM
  4. locked rotor amps (LRA)
    By vinod in forum Technical Discussions
    Last Post: 09-09-2006, 12:50 AM
  5. Fan Motor
    By Coolie in forum Technical Speculations
    Last Post: 16-02-2005, 08:03 PM
