    bhahmad's Avatar
    bhahmad Guest
    Cool Wet bulb temperature calculation
    I appreciate if any one can help me to inform me any easy formula for calculating the wet bulb temperature from air drybulb and humidity.
    Mar 2007
    India
    38
    Re: Wet bulb temperature calculation
    Perpetual motion, alchemy, snake oil and easy method for calculating WBT (when DBT and RH are known), all belong to same category
    I am a bit dramatic but the simplest calculation requires to compute 4 other parameters and 2 implicit equations (in simple terms, you should do a trial and error calculation or use iteration techique).
    Refer to ASHRAE Handbook of Fundamentals.
    11,025
    Use a physcometric chart.
    Nov 2007
    Argentina
    71
    12
    Excuse me, may be I didnīt understand you, but if you already know the humidity and the dry bulb temp, is just a matter of looking at the chart.
    May 2006
    India
    82
    1,013
    Since you are knowing the Dry Bulb Temperature and the Humidity, then the best way to know the Wet Bulb temperature is to use the psycometric Chart.
    Nov 2007
    Dubai
    52
    12
    Aug 2003
    Netherlands
    49
    620
    Just in case, here's one!
    Attached Files Attached Files
    Oct 2006
    CORDOBA -ARGENTINA
    75
    Despite all the valuable opinions, the tables where made by formulas , also a lot of software use such formulas.
    Of course it is easy to use the tables.
    Aug 2007
    Cyprus / Iraq
    52
    9
    is this for real????
  1. bubble temperature?
    By marc5180 in forum Fundamentals
    Last Post: 21-08-2007, 02:05 PM
  2. re ref. circuit
    By shsalameh in forum Fundamentals
    Last Post: 06-08-2007, 12:59 PM
  3. Q=? h1=? mechanical schematics
    By fridg in forum Technical Speculations
    Last Post: 19-03-2006, 01:43 PM
  4. Article in ACH&R News
    By Gary in forum Fundamentals
    Last Post: 20-05-2003, 12:27 AM
  5. Replies: 5
    Last Post: 16-10-2002, 12:38 AM
