Re: city multi PURY P250 YMF
I would think of the check valve CV1.
Thanks, I intend having a look at this in the next few weeks- before we need To go in to cooling mode. Apparently Mitsubishi do a check valve repair kit - you ever overhauled one ? I have units either side so only have access from the front and rear
1 Attachment(s)
I don't think any check valve is reparable, it supposed to be changed.
BTW, besides CV1, the CV7 check valve could be a problem. This valve works in cooling mode only.https://www.refrigeration-engineer.c...id=16178&stc=1
