1 Attachment(s)
York Chiller YCIV Suction Pressure Limiting
Hi Guys
Please see below data if anything seems abnormal:
System running at 100%
PRESSURES
Suction = 26 Oil = 177 PSIG
Discharge = 192 PSIG
TEMPERATURES
OIL = 123.4
SUCTION = 43.5 F
DISCHARGE = 159.4 F
SUCTION
TEMP = 43.9
SUPERHEAT = 13.2 F
SAT TEMP = 30.7 F
DISCHARGE
TEMP = 159.5 F
SUPERHEAT = 32.2 F
SAT TEMP = 127.3 F
MOTOR TEMPS
T1 = 120.5 F
T2 = 134.6
T3 = 95.6 F
FLASH TANK
LEVEL 29.4
FEED VALVE PERCENT OPEN = 46.4
SUCTION SUPERHEAT = 15.1
DRAIN VALVE OPEN = 54.7
CHILLER WILL SOMETIMES JUST SHUTDOWN AND NOT GIVE ANY ERRORS..WHAT AM i MISSING GUYS
Attachment 15781
Re: York Chiller YCIV Suction Pressure Limiting
pleas what is the application that this chiller is intended for?
Discharge pressure looks high!
