Soft Serve machine won't shut off
I am having a problem with a Soft serve ice cream machine that runs too long. It has an automatic expansion valave which is set for 20 PSI. The machine was originally charged with 502... I have retrofitted it with HP 80, (R-402A). I weighed in the correct charge and the machine will not shut off. The ice cream comes out a degree or two above the recommended dispensing temperature. How can it keep running without freezing up solid?
Soft Serve Machine Wont Shut Off
I agree that R-408 is the best replacement for R-502. I have used it in Walk-in freezers, Ice Machines, and soft serve machine without problems
Most of the "interim" refrigerants are a real pain, particularly if the system isn't completely evacuated and re-charged (new sporlan drier of course)
Truman;)
