Re: Degrees °C Centigrade
Hi Brian,
No can do.
I have it set up in Office 2003 but it dosen't work here.
Its the personal setting of the Signs in your computer.
If you explain how you did it on your computer, maybe I can do it on mine.
Chemi :)
Well it should, he says hopefully, because it is part of the ASCII code for symbols.
Try holding down ALT (not ALT Gr) and tapping out a few three digit codes into the numeric (Num Lock on) pad and see if you get anything at all.
If it don't work then I should have kept my mouth shut. ;)
{}ô°°♪☻○◘╒▼■♥ woww!!!!!!
you learn something everyday.
cheers
eggs
OK eggs,
Please explain slowly to a non English speaking person,
How did you do it and I couldn't? :confused:
Chemi :)
hello chemi.
first press and hold "Alt"
next press "2" release
then press "6" release
then "9" release
lastly release the "alt"
♪ should appear.
cheers
eggs
Sorry, Nope. :mad:
What Windows version do you use and which is your Browser?
It might have something to do with it.
Chemi :)
ie6 and XP.
Try MS Word, see if that works.
♂▬!B♥♠♦♣•█
keep trying
cheers
eggs
♪ Now ° you ☺ say!!!? ♀Ω↔≈ :rolleyes:
Chemi :)
That heavens for that....:)
I almost wish I hadn't started this :D
1 Attachment(s)
Now that Marc helped me, here is the full table.
Chemi :)
In your windows system folder (usually c:\windows\system32), there is an executable called charmap.exe.
Under XP, it can be accessed from :
Start - All Programs - Accessories - System Tools - Character Map.
Needless to say, creating a shortcut on the task bar or desktop or start menu will come in handy.
Double click on the symbol you want to insert. Click on copy (it copies to the clipboard). Then paste ... and voila.
