Re: Start and Run winding
https://www.allaboutcircuits.com/tex...uction-motors/
ThermaGroup / ThermaCom did a "Field Compressor Guide" PDF, is also a handy thing if you can find it
Hi Guys.
I posted the Thermacom manual in 2007 and surprisingly it is still available on Thermacom's Website!
There is a link at the bottom of their homepage. You have to supply some personal info. But If you cannot access it via my link (which i hope works?)
https://www.mediafire.com/file/ol3bl...group.pdf/file
Then it is still very useful and Bless Thermacom for providing such useful document. Because a good Engineer will always tell you. "If in doubt revert to the basics!"
Enjoy Grizzly
Grizzly,
Still very good information.
Not what was requested, but this link from Brainerd is pretty good for compressors as well
Start winding for start, then switches to run winding.
Run, Start,Common connection on compressor, work out using ohm meter.
https://brainerdcompressor.com/wp-co...ms_IN-1559.pdf
I did like the Info on Single Phase Motors. An area I am weak on.
This comment bothered me a bit however!
A three-phase motor may be run from a single-phase power source. However, it will not self-start. It may be hand started in either direction, coming up to speed in a few seconds. It will only develop 2/3 of the 3-φ power rating because one winding is not used.
II hope no one relies on this as in my experience it rapidly leads to Motor Failure!
NH3LVR
NH3LVR, would take it with a grain of salt.
Just informing what is possible, only MacGiver (or Knighty) would do it to get out of a life threatening situation.
I was just afraid an inexperienced person would try that!
RANGER1
is it bad that as I read that I was thinking you can make a single phase to 3 phase converter doing that (think you need to add a couple of capacitors too)
:-o
