I have a Daikin Model # FDYP100 Inverter Air Conditioning. At present the control panel and therefore the temperature senor that controls the System is in the Lounge Room. How do I change it so the system uses the sensor in the inlet ducting? I have an open fire in the lounge and with it on the A/C sense the Temperature is too high so it switches off. The problem is that then the rest of the house is to cold. Thanks for any help you can offer.
Ian
