The cooler you mounted inside the vacuum chamber, was this to cool the chamber or to help achieve the desired vacuum by capturing the water vapor via condensation on a cryocooler, a so called Meissner coil?
No the coils were being used as a final condensor for a difussion pump. Diffusion pumps boil a special oil and then condense the oil and this helps achieve a very deep vacuum.
The mix you were talking about is probably for the auto-cascade systems (polycold?)
This mixture is a secret from every manufacturer and is very, very expensive.
I use the factory gas and procedures on these regardless of cost or time. Auto-cascades are the one area that I read and follow EVERY STEP. I was refering to regular ULT refrigerants. Example, I had one in the shop that required R407D, which is not easily accessable here. The factory suggested to make my own 30% R410A and 70% R134A. I did the mix and gassed up the system. I did not like the results. My head pressure with no load was 175psig and my bottom out temp was -52C. When I applied the load, started the second stage, my head went to 260psig and I could not maintain a negative temp in my heat exchanger. I ended up evacuating the system and and re mixed another bottle of gas. It worked great.
The 'Techemshe' is in fact Tecumseh
Yeah, You will see I cannot spell:D
'l Unithé Hermétique (I would like to hear the US and UK members pronounce this once :D :p )
:eek:
I should say, if you encounter a problem, fire your questions in this forum. We will try to help you out.
Thank You Very much.
But it all comes back to the pure basics.
Luckily the guy I was working with started out at a ULT manufacturer. He also started working when it was simpler, R500 in the 1st stage, and R503 in the 2nd. He taught me the basics and built on them. But his knowledge ended once the manual ended. I like to know more than what the manual tells you. I like to know why it tells you what it does. That is one of the reasons that I am posting here.
I should recommend you to buy a good book about refrigeration and try to understand what's happening. A very good start is Dossat Roy, Principles of Refrigeration.
That book is already in my referance library along with the copeland engineering manuals. I have a good foundation in the basic refrigeration cycle. It is moving past the basics that I run into trouble. that is another reason that I am hear.
But that's the good part of it, by searching for the right cap tube diameter and length, you will have to force yourself to understand what's happening in this cap tube and what the consequences are by making it too long and too short
The longer the tube the lower the suction pressure and les volume of refrigerant. The shorter the tube the higher the suction pressure and the more volume of refrigerant. Right?
I have no one that I can go to for the answers. That is another reason that I am hear
This site is a huge resource for me. The poeple that I work with are repair people, all that they want to do is change out parts until it works. I do not suscribe to this philosiphy. This is not meant to insult my coworkers it is just a differance of opinions. They also dont work on ULTs. They work on the regular stuff, heating and air, and walkin coolers.
All that being said, I do not expect to be spoon fed all the answers that I ask. If I ask a stupid question I expect a equivelant answer. I have "thick skin". I know that I have a lot to learn and that some of what I ask I will be expected to know already.
Thank you for sharing your Knowledge.
