all reefer container problems/daikin/carrier/thermoking/mitsubishi
reefer mechanic
Re: all reefer container problems/daikin/carrier/thermoking/mitsubishi
Welcome Reefermechanic.
What ?, no StarCool ?
Hi. Iam a commercial refrigeration tech and owner. I was just recently asked to repair and services a thermo king unit M/N RD II 30. I am looking for a services manual or where to get one. Could you tell what kind of problems to look forword to.
Hi Will,
Only, MAERSK using Starcool unit.Also i repaired a few unit but ı don't know everythings about starcool unit.What happen??You have problem starcool unit?Maybe i can help you:))))
Hi Opieman,
I didn't understand you.But you must tell me right model.Your machine marine or trailer units??Beacuse on the Thermoking container units signs CSR,CRR and Magnum etc.If you give to me more information i will help you..
Best Regards.
reefermechanic
Hi Opieman.
İ think i found service manual of your machine.You need which one??
RD-II and RD-II MAX (TK40181-1-MM).pdf
RD-II Max (TK41023-1-MM Rev 1 10-27-03).pdf
RD-II SR (TK41131-1-MM Rev 04-03).pdf
RD-II TCI & RD-TLE (TK50394-1-MM Rev. 2-99).PDF
Also you give to me your mail adress.İ will send to you:))))
See you,
Reefermechanic
Hi reefermechanic and welcome.
I think your calling truck / trailer units container units. On this side of the pond, container reefers are "sea going" containers.
One last thing, you may get some flack for offering manuals here. If you decide to help someone this way, it's best to email them with the offer.
I apreciate your wanting to help but some others may not.
Abbs
hello i was sent to an old carrier container wwhen i got there room temp plus 20 no ref running turn stat to minus 10 ref ran set stat to zero fridge ran to plus 10 then
stopped turned down to minus 10 ref
restarted can you help?
why me?
Hi Why Me
can you say to me whats model your carrier unit??for example 69NT40 -489 etc....
Best regards.
Reefermechanic.
Reefer mechanic,
welcome to RE and nice to have a new member who are more than willing to help and share his knowledge.
regards,
Hi guys:
I have 4 carrier elite and thinline shipping container units rnning a holding room here. I would really like to intergrate their electronics with my plant plc so I could do things like initiate defrosts from it, and monitor them. Does anyone have any access to or ideas on either electrical schematics or interface programs for this?
thanks
Dan
Hi Dan,
If you just want the basics like manual defrost and temperatures, the quickest way in my opinion would be to tap into the manual defrost switch (MDS) inputs (KA8 & KB8 - for the older ML2/ML2i controllers). Refer to Carrier's manuals (which contain wiring diagrams) you can download from Carrier's website. Hopefully the ML3 still recognizes these manual defrost inputs as the ML3 can replace a ML2i controller. For reading temperatures, if your PLC can support temperature sensors, then installing separate sensors would be the quickest option.
The better but more complicated option: The MicroLink 3 (ML3) controller has a serial port which can communicate to your PC if you have the DataLine software. You can also download the latest Service pack 8 from Carrier's site (You'll need DataLine first though). If you're not bad at programming you can interface your PLC to the MicroLink directly but you'll need to figure out the communications protocol.
If you get desperate I'll try my best to find a better solution for you. Good luck.
Thanks, Ill start with that. we have pretty good programming assets, if I can get the software, we can probably make it all work. Ill update somewhere down the line.........
Dan
abet_meneses
Reefer mechanic,
regards,
hi there Reeferman, Iam am currently working on an old mitsubishi CPE53-2BAIIIPU container. have just finished replacing the main display board and now get 2 alarm codes that won't clear. they are 207 and 356. I am starting to look at the main relay board (P-MGC05) I have all clean voltage going to the board and the pahse sequence seems ok. The alarms tell me that the 207 is single phase and the 356 alarm is the current sensor. As far as I can see they all originate from the above mentioned board.
any help would be very much appreciated as the customer wants to rent the box out over the Xmas period
thanks for your time
Hi London
I have never seen CPE53-2BAIIIPU container.I don't know how is its??But if you send a picture and wiring diagram of reefer unit maybe i can help you..
I m waiting your kindly informations of reefer unit.
best regards.
reefer mechanic...
hi there reeferman , thanks for the reply. The mitsi box is now sorted. I did a factory reset with the dip switches on the main board (switches 6&7-moved them to the on position and powered up the container, then shut down and returned to the off position). I was told this by a guy who was an old hand at mitsi containers. this cleared the alarms that were hard latched in. I then proceeded to do a full PTI and the container passed. Thought this info might be handy to you and anyone else who may come across this problem
kind regards and happy holidays
:D
reefer mechanic.. can you please help me find a manual for an SB 310 thermo king unit????
Hello reefer mechanic
I have some problems with a ThermoKing CFIII M5.
This is the first container that i'm workink on, so, if you have some info (service manual, operation manual, etc),
please send it to danyelstoica@gmail.com.
Thank you very much.
hi exxe
I did sen to e-mail to your mail adress.Check please than back to me..
See you
reefer mechanic
Hi reefer mechanic,
I am looking for one kind of integrated reefer machine (except TK, Carrier, Daikin, Mit) with genset and one or two sets of refrigrating system. If you know any, please kindly let me know. My email address is hongbin.sun@cimc.com.
Thank you for your help in advance.
Gary
I fault with a TK sea container not controlling at set point +4 the liqiud line solenoid will not shut if you remove the coil the unit will pump down but it will not cut out on LP
reefermechanic
Hi All,
I m senior reefer technician.İf you have got any problem about reefer container units . i will be here....
All the best.
hi iceman uk here what is the weather like and any jobs i am a reefer expert with 25 years knowledge wanting to escape to sunny happy times
i need a wiring diagram for conection cable , i whant to get data from thermo guard micro p. thanks
Hi reeferman,
We have recently had a problem with a mitsubishi CEP52 reefer, It had low refrigerant due to leak on sight glass, replaced sight glass, drier, and evacuate and charge, now we have high head pressure and low suction pressure problems with little cooling effect can't get below 20 deg c, we think maybe problem with electronic expansion valve, any Ideas ??
Hi Andrew,
Yes ,,you are right.If you seen high head pressure and low suction pressure there is problem on electronic expansion valve.Did you check its??
Your unit is which one??
MMCCIIIA-52CPE15-2BWIIINV 2BAIIINV, 2BAIIIFV, 3BAIIIAV, A2V
I m waiting your reply..
see you
reefer mechanic.
3 Attachment(s)
AndrewB
Hi reeferman,
Andrew,
You have to check attached file.;)
Good luck.
Reefer Mechanic.
plz i have probleme with dakin for f 803 END F109; I WANT TO KNOW THE GOOD SOLUTION FOR THIS PROBLEME;THINKS MY TETCHER
Hi ReeferMechanic,
We changed the elextronic expansion valve, on the CEP52, now working really well, thanks for the tips
Cheers Andrew
AndrewB
Hi ReeferMechanic,
Cheers Andrew
Hi Andrew,
Thank for kindly reaply:) I have become happy if i help you..Where are you working??What s name your company??
See you ..
Reefer Mechanic...
Can anybody help ?. We provide trailer telematics devices GPS etc etc. We want to integrate it with reefer trailers, initially Carrier and Thermo King so that we can remotely gather temperatures and any other data available.
I need to know what data can be easily collected, is there typically a data port we can gather the data from ? what is this data bus, RS232 / 485, CAN etc.
Does anyboday have the protocols for communicating to/from the fridge units ?
We are willing to pay for any consultancy work
Telematics
Hello Everybody.
In my country haven't any freezer container and unit factory.
But I am researching to cooperate company who can supply to us freezer container. But, I need to know which way is better?
1st. We will studying workers then installing. /of course we must to purchase reefer machine like a Termo king, Daikin .... etc./
2nd. We will purchase completely product freezer container.
Actually our country is very cold in winter and summer time is very hot. So reefer machine must be work -40 +40C. And my countries climate dry. So reefer machine must be work in bad climate like a storm.
Please tell me, which companies reefer machine much suitable in my country? and how teach my worker?
oh there is one offer about installation inner and outer of container?
Best Regards
Ariunbold.Ts
aku
Hello Everybody.
Best Regards
Ariunbold.Ts
Hi Ariunbold,
You must check and select to the DAIKIN units;)
- <LI class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 14.4pt; tab-stops: list 36.0pt">Inside temp range –30/+30 deg. C <LI class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 14.4pt; tab-stops: list 36.0pt">Ambient temp range –30/+50 deg. C <LI class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 14.4pt; tab-stops: list 36.0pt">Reduced power consumption with the design of Daikin’s digital temperature control software (DTMS and DTMS2) <LI class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 14.4pt; tab-stops: list 36.0pt">Reliability in all weather conditions <LI class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 14.4pt; tab-stops: list 36.0pt">Low maintenance and Operational costs <LI class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 14.4pt; tab-stops: list 36.0pt">Operates using R134A (non CFC) – with the lowest GWP and subsequently the most environmentally friendly refrigerant. <LI class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 14.4pt; tab-stops: list 36.0pt">Compliance with industry environmental regulations and forward looking design to comply with future legislation
- Sensitive temperature control - to protect fresh produce from freeze damage
- Hot gas defrost system – providing the most efficient and fastest defrost available with less heat escaping to the cargo area, improving conditions for the cargo
http://www.daikinreefer.com/product-...vanced-design/
Nice to meet you..
Reefer Mechanic..
Hi my company The fair manufacturing Company, here is Cambodia has purchased a used 20' reefer with a thermo king c11 m40 refrig unit. It powered up ok but does require the coolant gas to be re filled/ re charged . Our local refrig guy (who is pretty good) wants to clarify what Coolant gas he is recommended to use. Also is there a recommended compressor oil to use ?
Regards and Thanks in advance for offer to help us out there in this brave new world !!.
Derek mayes
3 Attachment(s)
derekcambodia
Derek mayes
Hi Mr.Derek,
You will find all your need informations within atteched files.:)
Best regards.
Reefer mechanic.
