Re: Fact or Fiction
As the initially warmer water cools to the initial temperature of the initially cooler water, it may lose significant amounts of water to evaporation. The reduced mass will make it easier for the water to cool and freeze. Then the initially warmer water can freeze before the initially cooler water, but will make less ice. Theoretical calculations have shown that evaporation can explain the Mpemba effect if you assume that the water loses heat solely through evaporation [11]. This explanation is solid, intuitive, and evaporation is undoubtedly important in most situations. However, it is not the only mechanism. Evaporation cannot explain experiments that were done in closed containers, where no mass was lost to evaporation [12]. And many scientists have claimed that evaporation alone is insufficient to explain their results
