Hi, all:)
I was recently asked to look at a water chilling plant in a Brewery, I have some pictures of the plant. On it is fitted a WRV 321 Howden compressors with a retrofit plate heat-exchanger for cooling the oil. I thought I would post this as it isn't to often you see a rubbered plate as an oil cooler.
I will post again when time permits with the photo. Nice big screw, must be the biggest I have ever seen on water chilling, 3300volt motor fitted, not often seen in these parts.
Regards. Andy.:D
