Compressor problem I think?
3 y/o fridge freezer side doesn't stay cold all the time it will stay freezing for a week or so the things thaw and a cool air is blowing, I checked all vents for blocks' pulled back off and top of compressor VERY hot and fan was blowing? cold then cool cold then cool any Ideas?
Re: Compressor problem I think?
Good "sales pitch" but no ideas, sorry.
Have you checked that the freezer coil is not icing up due to a defrost problem? This should be at back of freezer.
You could possibly have moisture in system or a blocked capilliary. Does compressor sound unusually noisy or struggling before unit shuts off.
Has any work ever been done on the system ?
If you switch it off and leave it for 24hrs does it then run OK for some time before it fails? If so how long?
I think you'll possibly have to get an engineer in to have a look at it.
ECM
