Hi everybody,
I am asked to design a water chiller to cool water with temp. of 40°C which flows constantly with low flow rate.
I think that with one chiller this would be a problem because of high entering temp.
I want to use two chillers with one heat exchanger in between, i.e. cold water from the first chiller goes into a plate heat exchanger then cools the 40°C water to 15°C then this cooled water enters the second chiller.
Any comment will be appreciated.
Cheers.:)
