Hello,does anybody has an engeneering book for the Stal S93 compressor? Or other documentation is also welcome. Thanks in advance
Karel,
Do you want to overhaul compressor, or what would you like specifically.
I need to replace exisiting Stalmatic by new regulation on several compressors,but it is not clear how to commmand the external components ex.oil pump/pre-lub valve/Vi-slide etc..
Grtz.
Karel,
you need more Stalmatic documentation.
Which Stalmatic model do you intend to replace? do you replace with which PLC?
Ideal for you Unisab from JCI, there you will get everything you need and even instructions.
Josef.
I put UIII retrofit kit on two old Frick 193 compressors and its running perfect.
Only problem can be the price. Its crazy expensive.
AKI,
insanely expensive, but it works perfectly. The basis is SW, S93 does not have a moving Vi-if I remember correctly and in that case creating SW with another PCL is perhaps not such a problem that will also work. With Unisab you get all the information about the settings.
Josef.
Ok,thank you for the info.
Karel,
contact JCI in your country for information on item 3088.515
Josef.
