Replacement of r404a compressor
Dear All
In a refrigeration air dryer the refrigerant Compressor MANEUROP MTZ72HN4AVE burnt and must be replaced. In the local market I didn't find the same compressor but I found the model MANEUROP MTZ80HN4AVE (little bigger).
Its ok to replace the refrigerant Compressor MANEUROP MTZ72HN4AVE by MANEUROP MTZ80HN4AVE.
I am waiting your comments.
Best rgards
Re: Replacement of r404a compressor
You did not state what refrigerant is in the system but any other make for the same refrigerant and POE oil, with the same pistons volume will do.
Using a larger capacity compressor will lower suction pressure and might freeze the evaporator.
