Panasonic CS-W24BB4P Daikin Equivalent 2001 Heat pump R407c?
Someone else has posted the same question last year, but was wrongly told that this wasn't a Matsus.h.i.t.a (damn foul language filter, good job I'm not based in s****horp). manufactured unit. I can confirm that this manufacturers name is all over the unit.
It is dated 2001 and can cool / heat using R407c.
Two issues I need a indoor pipe thermistor 25°C = 20KOhms....same as many Daikin units.
The main issue is I need to replace around 20off filters / Grill (Fascia) to make the system look new for the clients new refurb....he hasn't the money to replace at this time.
Part number Panasonic CZ-BT-01P.
Since Panasonic are no longer supporting this unit I need to get spares from Daikin.
Anyone help me?
Which unit is the same Daikin....twin unit on one condenser.:confused:
Re: Panasonic CS-W24BB4P Daikin Equivalent 2001 Heat pump R407c?
The only Panasonic range that was re-badged Daikin was the Urban range.
The model you have is from the Panasonic Flexi Range.
Spares for this may still be available from the Panasonic dealer Oceanair
The other alternative is to either clean them with 'Flash with Bleach' or have then spray painted
Is that Paul?
Last quote I got (Oct 2013) was from Dysk, £120 inc delivery, in stock (Panansonic or Dysk, not sure where).
Definitely a non Daikin unit, got the Panasonic remote not the Daikin one.
Might be worth trying or get the paint pots out as Frank suggests.
Cheers,
Andy.
Definitely painting, this panel is very old, not even supported for spare part delivery by the Panasonic Service Network.
