Needing some help with finding a service manual for a Frick model RWB II -399Plus
Any help i would greatly appreciate.
Thank you.
email: Svetoslav_4040@yahoo.com
Thank you.
Sir, you have experience with such a large compressors? need a lot of special tools, send to the factory in France or Denmark, for you security.
Josef
We are on the planning stage of the project. We have two RWB II -399Plus, stored since 1991, but we don't have any technical information about them.
http://www.johnsoncontrols.com/conte..._-_610_sed.pdf
There is a bit of information on the internet, depends what you want to know exactly.
That's a long time sitting idle, are they still pressurized with nitrogen or filled with oil for protection.
Would think shaft seal minimum would need replacement.
Hi, hrrs :)
welcome to RE forums ....
hrrsRe: FRICK compressors RWB II -399Plus
Please, visit this link below and search for yourself ....;)
http://www.johnsoncontrols.com/conte...mpressors.html
here you will find as follow:
- Rotary Screw Compressors (PDF)
- Installation, Operation, & Maintenance (PDF)
- Specifications, Engineering Data, Dimensions (PDF)
- SuperCoalescer™(PDF)
- Frick® SuperFilter™ II (PDF)
- Vibration Analysis (PDF)
- SuperCoalescer™ (PDF)
- Frick® 1-2-3 Proactive Protection Plan (PDF)
- Can be sized and selected in Coolware
- Make Your Compressor Last (PDF)
- Vyper Service Parts List 305/254 & 437/362 HP (PDF)
- Vyper Service Parts List 700/572 & 912/752 HP (PDF)
Of course, if you need some more info do not hesitate to contact us ... we'll try to help...
There is one forum .... for new members ...
http://www.refrigeration-engineer.co...p?72-New-to-RE
where you can introduce yourself .... what will be very nice ;), thanks ....
Best regards, Josip :)
Actually, we dont know, because they are packed.
I saw the pdf file, it would be great if it was for RWB II, but I think we can use some of the info
http://www.genemco.com/catalog/frickcompressorPC01.pdf
This any good, it's on the net
hrrs, suggest you contact Johnson controls & explain your circumstances, they may help out.
Hi i sent a manual to email address supplied let me no if you dont get the manual
