Any one still playing with this jooce?
I suppose there must be a few drums lurking about, but it's totally illegal in Europe.
________
vaporgenie
Illegal here to . . .
Its been banned world wide Im told. It was the best to work with , negative standing pressures, dont leak .
Hi, I was just on ship that still has York LTD with R11.
They don't have enough to continue to run so they are asking for a retrofit.
The R123 is a possibility but I heard there is another one available now ??? because R 123 is dangerous (gives cancer) , do you know this new one ???
Originally Posted by Greg W
.....you could wash your overalls in it, too.
________
vapolution vaporizer
Also you didn't need gauge lines, you could just pour it in:) Wasn't it one of the first refrigerants to be phased-out in Europe in the early 90's:confused:Quote:
Originally Posted by Argus
Hi, I believe they still manufacture it in India
Originally Posted by Toosh
Quite probably they do.
This is because India is an 'Article 5' country under the terms of the Montreal Protocol.
This allows certain developing countries a per capita allowance of CFCs.
________
BMW E83 history
Hi Greg, The negative pressures are bad if you have a leak they suck in air when they are standing still, believe me ive had my share of problems in that area.
I have seen a toy bird (basically a heat engine decorated to look like a bird) that uses R11 as the working medium.
Use to (many moons ago) have a bucket of R11 next to me when i stripped down compressors.... great for cleaning the sh*t of parts...
Hi. http://www.r22.org/ Found this site very interesting
I can't believe it's still available. If we come across an R11 system that has been leaking we must recover any refrigerant and send for disposal. The system MUST then be scrapped or retrofitted. :) Thats Australia
Hi:)
I recovered some recently. Opened the valve at the bottomof the condenser float chamber and sucked it into some recovery vessels:D
Easiest refrigerant I have ever worked with;)
Kind Regards Andy:)
Was good for cleaning out a burnt system
:rolleyes: Was good for cleaning out a burnt system
Hi Greg,
We have still have about 3000Kgs of CFC R-11, Virgin stuff and distilled also at our Sydney warehoure. Also about 1000Kgs of CFC R-12.
And to purge the air when the chiller was running there was a valve on top of the condesor to let air/R11 escape. Thats why it is panned.
What to you indent to do with this R11 and R12?Quote:
Originally Posted by Graeme Blackman
I am curious what it can be used for in todays time and regulations.
Hi, anyone knows where to find R245fa in Europe?
I think this will be the best R11/R123/R141b replacement but im not being able to get it.Guess ill have to still go with R123...
You could try BOC... sure there is some round here.
Teach me to search old posts.
R245fa comes from Honeywell (BOC stock) be warned that the current production is foam grade but they will mix up some nice clean stuff if you ask. We have been on R245fa since 2002 and R11 it aint. Honeywell were working with Ecotez on a flushing system that was an IKK this year.
Oh and they also do a flushing grade of R245fa mixed with a stronger solvent.
Negative pressure R11 chillers were a real pig, I had one leak like a cullinder, loose its vac overnight, held 10psi over a weekend, turned out to be flattend O ring on the oil cooler, made sure I change every O ring I ever disturbed on R11 units after that. Its hard to find leaks that leak inwards!
Hi.The R11 is still in action.Just been in Singapore for retubing of one chiller .The subcontractors was using it to clean the system.
I do belive they get it from India/China.
I do agree it has been banned in Europe for many years.
Many of the old ships has still the stuff on the plant.The old reefer ships from Russia still have R12 on ther plants.
HGS
Suck in air is true. All R11 and 123 chillers ive seen have had purge units attached, These units have counters so you have a Idea it the leak size. If you develope a moderate leak , you can still save 90% of the charge. Try that with a positive pressure refrigerant. Plus I have chemical Info sheets on R123 that state its not as harmfull as lead to belive. Its the doing of a certain company that produce 123 chillers and there properganda to stop others from using there bad ass gas.
There are still people around with a stock of R11 but they canīt sell it.
Some York OT (LTD compressors) are still alive in North of Italy. Some retrofitted with r123, others with original R11 refr. Customers fill the warehouse of R11 drums in order to have refr to spare.
Air Purger is basic to the good chiller run. In the low pressure side it's difficult to trace a leak. I hate it !
hmmmmmmmmm......
I'd be very quiet about that if I were you !;)
There's no legal way that you can put CFCs into a system any more. It's just as illegal in Italy as it is in any other EU country.
Just because they get away with it doesn't mean that they won't get caught.
:cool: well, we only note that some of this groups are running, but no one of my organisation put hands on it ! Anyway, there's anyone that can charge and service this chillers (and fill refrigerant on it), but they run and run, and run.....:confused: :confused:
What would you do if you had a stockpile of r11 or r12 , sell it illegaly? Personaly I would return it to the supplier for a cash back per kilo. The Manufactories of these world deadly refrigerants should be held responsible for there product.
At my workplace we changed out our old R11 refrigerant to R134A and just got rid of 60gal of the stuff that had been sitting on our loading dock for 2 years. Being a government department we pawned our barrels off on another department. Strange thing about government, everyone else has to follow the rules but them......
no, ours was converted from an R11 to a R134A. I don't know what had to be changed for this to happen as I wasn't involved in the change over. But in the building I am currently in everything gets done because the silver rings say so and no other opinion is taken into account. It's just another reason i'm leaving government.
Prevac, Prevent just a couple of stratigies for prevention and removal of non condensables.;)
