Looking for a schema, service manual wiring diagram for the unit THERMOKING SL 400e.
The problem with de-icing. Defrost
Flap does not close. servo works when connected to a battery.
s.sawicz@clemente.pl
theres a solid state controller inside the relay board box,
bolted up by the das, it'll be that
Linkage connecting motor to door often come adrift. Also motor has a heating element which energises below freezing. If this fails damper may not work at very low temps.
Thank you for the advice. The fuse is OK. Check out the other as soon as the trailer back
