Re: Osbourne no fan access
If its the same as the one i changed a few years back, there is a few screws holding the plate that the compressor and condenser is mounted on to the chassis. once these are removed there is enough room to slide out and twist the unit to gain acces to the fan motor.
If its not the same, give Osbourne a call, which is what i did and they explained how it comes apart!
Jon
sparkout
(who designs these things)
:mad:
Possibly the same bloke who designed the Citroen BX turbo diesel.
The post about how to remove is correct ,the problem you have is you are giving info to a non refrigeration engineer,try doing same with your TV./Microwave etc they will tell you where to go ..............sharpish
willies boy
So we should be as unhelpfull as the 'tv repair man' in your example? Surely it would make for a horrid world if we were all unhelpfull.
Where would we be if nobody every passed on any knowledge to another, most likely we would still be living in caves or such.
I try to leave everyone i meet better, and if i can't manage to do that then at least to leave them no worse.
Jon :)
