Does Frick make their software available? I need to look at propane capacity of a TDSH 233 economized unit and don't have the software. Can I use Mycom software for equivalent rotor size?
It is available to "Frick Factors". If you can't find the info you need let me know. I may be able to help. What are the operating conditions and the motor size? Is it a S,L or XL?
TDSH233S, short rotor, -5F saturated propane suction, 110 F condensing (202 Psig), economized at 3550 RPM with auxiliary glycol cooled oil system.
Evaporator load: 219 TR
Compressor power: 438 HP
Mass Flow suction lbs/min:308.8
Mass Flow discharge lbs/min: 423.3
VFR (cfm) suction 959.2
VFR (cfm) discharge 231.4
I hope this helps. If you need more info please let me know.
sorry i want TDSH 233 Capacity ( kw )
