Hi friends, One customer he said me, that he see one system with CO2 over fruit before enter to IQF.
Somebody can help me with the system.
Only if you promise not to laugh!
I haven't seen mechanical CO2 applied before a IQF but in EMERGENCY situations something as simple (and expensive) as buying dry ice, placing in an insulated container with two openings you blow hot air trough one opening and get really cold air + gaseous CO2 out the other opening and on the product. Used in ventilated areas!
Someone that doesn't know refrigeration could have thought this is a CO2 system before the IQF, though as I said it is an EMERGENCY aid when the IQF cannot cope with the load.
They may be talking about using CO2 as an expendable refrigerant to pre-cool the fruit before the fruit enters the IQF. If this freezing operation is only used for one season during the harvest it might make sense to do this.Quote:
Originally Posted by mauricio Fort
Hi, :)
you are right Mike ... maybe like this ...
more about here ... http://beachberryfarms.com/behindourlabel.htmlQuote:
Originally Posted by http://beachberryfarms.com/behindourlabel.html
kind of DIY ;) to preserve harvest ... believe not too much expensive ...
Best regards, Josip :)
Who's Mike? ... Oh you mean Us..ok I get it!
Josip your post is right but for cryogenic freezing, not as an aid to an IQF!
Dry ice spray is much used these days in place of nitrogen, because CO2 doesn't change the colour of foods being frozen.
Eg.: Findus does this. There is case study I read in which they compare hamburger freezing the traditional way (190 grams in 11 minutes in a blast freezer) against CO2 ice spray (90 seconds core frozen).
And please donīt tell me you are saying you would place a CO2 cryogenic IQF freezer in front of a watever IQF Mr. mauricio Fort has in order to do exactly WHAT with it?
Hi, GXMPLX :)
You've heard of, nice, but some people on this forum maybe not ...
I do not know about production expenses, are you sure ...? Really, I do not know, but (IMHO), it must be more expensive to get a liquid nitrogen (4 or 5 stages system-maybe I am not right;)) then to get a liquid CO2 with a single stage ammonia system ....
.... however, it is maybe possible, because N2 you have within air (78%+) and easy to get into liquefaction plant, but to get CO2 you need to have some plant (brewery or similar) where you have a clean CO2 as a waste - not exactly ....
Hi, GXMPLX :)
... I must admit my English is not so good and this question and its meaning I do not understand fully, but ...
... let me ask you one question ... did you ever work on industrial freezing tunnels for sensible fruits like berry on particular plants and trees ... if your answer is yes, then you should know how important is to preserve it whole to obtain A class product (put a pack into microwave machine and you have just picked berries) .... there are people ready to pay for it ...
... so for me it will be ok to use dry ice (small amount and not expensive) to freeze a skin of berry and proceed with normal freezing in any tunnel (I prefer ammonia) to obtain A class product - very expensive one ... that sounds reasonable to you or not ?
But I can be completely wrong .... I do not know everything...
Thanks Josip, my day started to improve ... a little ..., at least I learned or should I say re-learned-membered that Scroll compressors might need a suction muffler if you don't install a U bend in it's suction.
:off topic:I must apologize to you for this was really a rhetorical question but as my wife says I may have a caustic sense of humor :mad:other people don't understand and gets mad at me.
Don't tell Mi ... er ... Us ... er ... well ... Him about this or I'll get canned or whacked again!
CO2 prices depend heavily on closeness to factories and may be the dominant factor here.
Have a nice day!:D
Exactly, berries are the center core product for dry ice flash freezing.
And it is also quite easily separated from nitrogen, with fractional distillation of air, or some other industrial byproduct.
And he/him/a mod was watching too.:(Quote:
Originally Posted by GXMPLX
It is not uncommon for some processors to utilize a pre-cooling section. This can substantially increase an IQF capacity. I've heard of using some hi-temperature evaporators and even the use of liquid CO2.
I think a lot of this depends on the type of IQF and how they try to prevent product clumping also.
Tks, I always need a reminder big brother is watching me or wife!.
Yes, maybe Mr . Fort should first give more details on the type of IQF too.
Every cryogenic IQF has a pre-cooling section thus I rule them out in this case.
I dont think doing it with CO2 is precisely economic but depends also on the product and quality improvement, of course.
We ... (or I'll) better wait if Mr. Fort can tell us more details.
