Copeland semi-hermetic compressor
Hi there, Since 3 years ago I got three european refrigeration beds (Zanotti) with Copeland (EWL) semi-hermetic compressors(3 HP), two of them are dammaged. They were manufactured in 1990. I´m trying to look for the American Copeland equivalent but provided with oil pump system. Can anybody give me light in the subject?
Re: Copeland semi-hermetic compressor
Do you know displacement of old ones or their model name?
Hello balam i think you have DLLB 301 EWL or DLSGB 301 EWL compressor which are a splasher lubricated , you,ll need DLLP 301 EWL or DLSGB 301 EWL which are a pump fed but you cant put a oil switch on them , the pump is at ther non drive end
Thanks Ghaz,
The compressor model is DLJ-30X; 3 Hp; 50 Hz 14.5 m3/Hr.... It happens in this part of the glove we use 60 Hz... Semi-hermetic compressors with splash lubrication is quite old and weak..looking for new predeictable one that can match with the others in the bed.
Thanks Ghaz,
This is direct replacement: DLF30X
Thanks NIKE123, I appreciate it.
