John Hunter
I can agree with all above. It sounds as if the "Frost Heave" has damaged the original structure including the vapour barrier. Defrosting will only allow the water to permeate further and if the insulating materials are expanded poly it will prove impossible to fully remove and will have to be replaced. Under floor heating in a freezer location is a must as even with a well insulated floor perma frost will effect the substrata. If a permanent lasting repair is required the floor will have to be rebuilt. The cost of such repairs may be such that the original structure is best condemned and a new facility built correctly.
