Discharge Desuperheating Good or Bad?
Real example: R22 100Tons/cir
Actual discharge surface temperature 5 cm upstream of injection inlet 78`C
Reduction discharge surface temperature 5 cm downstream of injection inlet 23`C
Shell & tube condenser, water cooled, 25% capacity, condensor TD 3K, constant flow, low head.
Would expect 1.5K diff!
Chiller available to view.
Any comments????
Any views as to how effective!
Hello Dan,
Having read many hundreds of posts made by yourself and Marc over the past few years... and saying that, I can thank you both for a few things that contributed towards my knowledge in fridge.
Posting the above was just a quest for further thought and insight into the subject. I dont think you are missing anything.
Just wondering if LI desuperheating into discharge vapour is effective or not.:confused:
