Re: Saunier Duval Problem
Check you mains voltages: three units exhibit the same problem, unless they were installed with air in the system and are overheating because of (damaging) non-compressibles - some Q&C (quick and cheap) installers just "blow out" air (bad practice and illegal in the EU) Can you describe the units? Some SD units are far East standard rebages. From the Eurovent pages they ring familiar as low cost/efficiency R407 units with a small outdoor unit? What is the pattern of the flashes? PS tried to get some sense from the SD page... No comment, their scripts do not seem digestible on my PC.
