Continue theme Bearings Frick XJS/XJF 95-151
Hi All.
I have overhaul compressor XJS 120 and finished work installation jackshaft. New bearing SKF factory with mark YOR.534B0101H24. I measured axial play and saw standard in play 0.025 mm. for 2CL series. Why then in service manual I see two different a picture: between a bearings two shims (any for install) and picture without a shims. After installation any we will be reduce the gap. What must be gap (axial play) on jackshaft, after close housing of shaft seal...?
Kind regards
Re: Continue theme Bearings Frick XJS/XJF 95-151
Scruw,
In jackshaft manual in indicates only a small number have shims by serial number.
Housungs are a different thickness to also identify.
0.025mm would think is minimum.
Cannot see anything for 120, only XJS 151 0.25 to 0.125 mm end float.
Hi RANGER
Thank You for answer. I save gap 0,025 mm.
Will be observe compressor in work.
Thank You once more..
