ThermoKing V-500 max
Can you please try to answer me one question. I am servicing thermo king V-500max, and I changed the ***** form r134 to r404. It is possible to change that parameter in a computer with a in cab controller? I have to change that because unit is shutting down because of the difference in the pressures of r134 and r404.
Thanks for your answer
Re: ThermoKing V-500 max
Change the hp switch and cond fan control switch
expansion valve is different as well.
Everything is ok. The computer was damaged so I had change it, but the software on a new computer was set tor r134. My system is working wit r404, so I have to change the parameter on a computer from r134 to r404. Probably I have to install new software on a computer.
