Does anybody know what these codes are ?
01 06 and 1E are the ones that have been showing at a site I have been working at.
Hi suctionheader .
Download from the link I have provided and the codes are explained.
Good Luck Grizzly
http://www.mediafire.com/?sharekey=0...b07cc7f7a4c543
Not all the codes you state are there though.
What is the actual unit you have a problem with?
Follow this link
http://www.realtime-controls.co.uk/p...iss2.00.00.pdf
The first part of the code is the unit number, the second (06) relates to how many times the electronics have tried before finally giving up and the last part is the actual error - in this case, High Dischage pressure
Hi Suctionheader,
Sorry Frank you are wrong. There is no count for electronics trying to start then giving up. (but some models have a compressor start count)
I think the codes should read
01.0b
01.1E
The 01 is the master unit
06 is actually 0b and is a float switch trip - check drains \ pump operation.
1E is the compressor discharge temerature exceeded 130C - check air flows (in & out), gas charge & Td sensor.
Hope this helps
Loops
http://www.refrigeration-engineer.co...ad.php?t=16639
Latte
............ Listen to what Loops says, he knows the kit inside out.
does it matter what order you wire the p q wiring in a multi modular 407c?
Paddyaircon,
I'd sugest you should have started a new thread for this enquirey but seeing as you've asked a question........
The PQ network on the old R407c 2-pipe modular multi is a non-polarised network. Just wire from one end to the other (not ring main style).
You'll need a 1.5mm2 2-core screened cable minimum.
Loops
Just had a call from one of our engineers and hes got P10 code up on the controller.
Its a RAV unit,
I told him to ring Toshiba Technical, as P10 isnt listed :lol:
P10 is "Float switch open circuit (high water level)"
Eggs
Thanks Egg,
I have just come back from another call with that fault and after going through all my Tosh books i couldnt find anything either. Had booked it to go back after speaking to Toshiba but thats saved me a phone call
Latte
