Quick freezing of fresh products
To everyone who is proficient in quick freezing rooms
I am working as an engineer in russian refrigeration company.
I have some questions on quick freezing rooms. At present it is necessary for me to design freezer room for quick freezing of ravioli. I am not proficient in designing such kind of rooms, so it is interesting for me:
1) What are your recommendations about selection of main components of refrigeration plant:
compressor, air cooler, air condenser?
Dimensions of room 3 x 2,5 x 2 > volume is about 15 m3
Product inlet temperature +20 o C (68F)
Product outlet temperature –12 o C (10F)
100 kg of ravioli
Necessary time for freezing 1 hour
Temperature in cold room: -35 o C (-31F)
I am going to use 2stage compressor (DORIN). Air cooler and air condenser Lu-Ve.
2)What should be the meaning of freezer room temperature?
3)What should be the difference between room temperature and evaporating temperature in such kind of freezer?
4)What is the temperature I should choose compressor capacity at?
5)What are the criteria of choosing of evaporator (air cooler)?
6)What should be fin spacing of air cooler?
Russia, Moscow September 13 2002
Re: Quick freezing of fresh products
Hi vishal here,
Does the latent heat of fish or any other product change according to the capacity?
Questions,
Are you freezing as a batch only (no storage) 100kg in freeze 100Kg out.
Very important!
How are you going place the product on side the freeze.
Best is many shelves with very thin layers, and an air gap between.
Air velocity of product needs to be in excess of 5M/S
Allow for floating SST (freezing point likely to be -2 to -5C)
Condenser size most critical, either size for SST -10C or install CPR
Defrost, hand intiated during unloading (temp terminated)
Rate duty at -28C, but allow system to run to-35C
