Dear friends,
Does any body heard tank and plate type evaporator instead of tank and coil type
evaporator. If any body have details on this please forward to me or give some
reference.
Dear friends,
reference.
need more info Kartheekus ?
plate heat exchangers http://www.danfoss.com/businessareas...exchangers.htm
tank type evaporators is basically a bare tube coil installed in a tank either at one end or in the centre of the tank containing chilled liquid ( water, brine, etc ). the evap tube coil is seperated from the sides of the tank by a baffle the coil inside the tank is usally flooded during the cooling process.
plate evaporators there is some info here for you !!
http://www.brighthub.com/engineering...les/61270.aspx
there are diffent types of evaporators for different appliactions
just to elaborate on my last the coil is not filled with chilled water or brine its the tank !!!
Try this:
http://www.tranter.com/pd/pc/dsn
I have used them before. This one is for liquid but I believe they have ones pressure rated for refrigeration.
http://www.htt-ag.com/images/teasers...less-steel.jpg
I think that this is what you are after.
